HELP-Any one got/ KEF THX TDM SPKs
Discussion in 'Home Cinema Speakers' started by Jas, Jul 26, 2001.
  1. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Noticed a few people on the forum have got the above
    Can u tell me which speaker stands you use for the TDM 23 F fronts ? I quite fancy the kef mdf based stands that are shaped like the speakers. i`ve rang kef and they say there unavailable till september due to supplier problems. or do you know of an alternative stand or base. is it possible to copy the design of the base and make them yourself? Or does anyone know of a retailer who has stock many thanks Jas.
  2. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Come on guys you can`t all be on holiday. i know some of you have this system so please help !
  3. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,497
    Norfolk
    +168
    Try Practical HiFi in Manchester. I am sure they were using the MDF black stands in their dem room last time I was there.
    Worth a phone call!
  4. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Thanks Edgeyboy will give them a ring.<br /> Nice to see someones awake ! Cheers Jas
