jibberjabber
Can any owner of the 32LD7200 Hitachi please try this for me but be careful, if you take your cleaning cloth that you use on the screen go to either left or right side upper of the screen if you apply gentle pressure does the panel itself move backwards and fowards? within the frame
, you might say it would seem the panel is mounted badly and gives a noticable amount of movement abnormal in fact with very light pressure.
Went to clean my screen today and the panel was clonking backwards and fowards within the frame
Hitachi are stating this is not normal and need to know if any others do it.
Regards
Regards
