Help and advise needed on Freeview
Discussion in 'Freeview & YouView' started by Crocodile JD, Oct 22, 2003.
  1. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Hi guys
    I'm after free view, but don't know anything about it.
    I want it as much as anything to pipe terrestrial stuff (champions league, world cup rugby etc) to my projector which has VGA, Component, S-video and composite. Obviously I want the best video transfer I can get whatever that may be? I would want general stuff to go to the TV which has s-video or RGB via scart.
    Is a freeview set top box the right way to go and if so which one and how best to connect. Also, do I need or am I better off with a special ariel?
    thanks in anticipation
    Croc
  2. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Any sports from ITV digital will look horrid on a projector.
    BBC 1 digital will be ok.
    Get the aerial checked out by a pro.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,975
    Some (but not all) freeview boxes have an SVideo out as a separate socket (mini-DIN). You could and should use this to drive your projector. Choose a box with this feature.
    You will also need to take an audio signal to an amplifier. Very few freeview boxes have an optical digital out, but the majority have regular audio L&R as RCA phono sockets.
    I think that most or all have RGB via SCART and you should use this to drive your TV.
    If you want to timeshift broadcasts - consider a 'Pace Twin' which is an integrated Freeview box and Hard disk recorder. It has the outputs you need.
    As for a new aerial - this is wholly dependent on the signal strength and which transmitter you currently use for analog.
    If your current transmitter is broadcasting freeview (most of the main ones do, but some smaller repeaters do not) and the signal for analog is clean and strong - you may well not need a new aerial.
    If you need to go to a different transmitter and/or the signal is not wholesome - you may well need a higher gain, and/or wider-band aerial. A decent local aerial contractor will advise. They don't cost a fortune.
  4. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    Currently I think the only Freeview box offering a Component output is the Netgem i-player.
    As already mentioned, most of the others provide composite, S-Video or RGB, typically via SCART.
  5. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Thank you all for the replies:
    Wayne
    Why is this?
    Nigel
    A most detailed response, thanks again. What reciever only gets the vote at the moment?
    AOB
    I have seen from other threads that you are actively after a freeview box yourself at the moment. Is it the PAC-TTR210T that you are considering? Would this be one that I should consider?
    Croc
  6. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    I take it you don't watch BBC1 then, where it's been heavily 'advertised' for the past year or so.
  7. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Kevo
    I am well aware of freeview, I was referring to the hardware side of things. I guess you would recommend the Pioneer? As I said I also need S-video and RGB out. Dig Audio would be ok as well since my reciever has a ready input.
    Croc
  8. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Too low bitrate.
    My Grundig GDT 2000 is great as well.
  9. bobones
    bobones
    Jan 15, 2002
    453
    +7
    The netgem offers only composite out of its second scart so component from the first to the projector and composite to the tv would be the best it can offer.
    As far as I know, for simple freeview stbs, only the Pioneer and the Philips both do s-video from the second scart as well as RGB and s-video from the first. I have used the Philips, and it is a very nice box, but I believe the Pioneer is the better machine because it quicker, has better graphics, and the Philips will never get the 7 day EPG. Both have digital audio outs: the Philips is coax, Pioneer optical. The Philips also has analogue phono outs. (Note the Sony also does s-video from its second scart, but only when negotiated with a smartlink compatible recorder).
    These two are your best bet unless you want to go down the road of RGB splitter/amplifiers and RGB/vga or RGB/component convertors.
    On your second question, only get an aerial upgrade if you are experiencing difficulty receiving all Muxes without breakup.
  10. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    Yes I am considering a Pace DTR210T, in fact I ordered one earlier today.
    As to whether it would fit the bill for you, that rather depends on your priorities. I like the slimline styling and decent connectivity. Lack of component output isn't an issue as none of my displays presently will take component. Depending on how I get on with it, I may even invest in a second unit for the lounge. It would fit the bill very nicely as I could then switch the s-video signal via my AV32R and simplify some of my connections.
    That would have the beneficial side effect of winning me some major brownie points with the other half! :laugh:
  11. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Thanks guys.
    OK, so I know what boxes to look at, but one final question. Given that the main reason for going freeview is to provide a TV signal to my PJ and given that Wayne has stated ITV digital would look "horrid" on a PJ, am I going down the right route. Is there another (better) way of piping regular TV to a PJ.
    Ignoring the subscription charges for now, purely from a technical point of view, would sky or cable offer better results on terrestrial?
    Croc
  12. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Not particularly, I have cable and freeview and can't tell the difference between pic quality, incl. ITV, although C5 and QVC is a bit iffy in Freeview nationwide.
  13. LV426
    LV426
    Jul 14, 2000
    12,789
    +4,975
    The PQ of the major TV channels (1-5 at least) is more than adequate, even for a large screen. I know. I drive my VW10 via SVideo from my Pace Twin and it's just fine. A little more pixellation than from DVD, but not intrusive.
    Can't speak for cable, but $ky is definitely worse on the 'free' channels.
  14. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Excellent thanks guys all i need to do is go shopping then:smashin:
    BTW nigel how much storage space have you got on the Pace twin? and do you ever copy it over to VHS or other?
    Croc
  15. LV426
    LV426
    Jul 14, 2000
    12,789
    +4,975
    Pace Twin has 20gb HDD which gives 10 hours storage. Personally I have not copied anything from it to a VCR - because I haven't wanted to. But I'm pretty certain it's a simple matter.
    I gather (from others) that the HDD can be replaced with a higher capacity one - it's just a regular 2.5 inch HDD such as you might use in a (small) PC connected via a standard IDE connection and power plug. Can't speak from personal experience, though. There is a thread on here somewhere on this very subject.
