Help and advice would be greatly appreciated!
Discussion in 'Plasma TVs Forum' started by mattboyslim, Jun 9, 2005.
  1. mattboyslim
    mattboyslim
    Mar 21, 2005
    104
    +4
    I will be purchasing the pv500 and I have also ordered some m-cubes. I was just wondering if anyone can recommend a dvd player in the £500 region that would work well with these. I also have sky plus. Would I need an amp as well, if so any ideas?
    Any advice would be great as I am totally new to this and am not sure what things are needed? :lease:
  2. Parklife
    Parklife
    Jun 9, 2004
    566
    28
    +33
    Yes you would need an amp. All depends on what your budget is as what to recommend.
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    Have you asked in the DVD players section?
    I have just bought a PV500 and was recommended a good DVD player by Hornydragon, It is a HK DVD25 from the classifieds, only £105, should look good with component.
    Some like the Denon 3910 and Samsungs , Panasonic S97, Arcam DVD79, not sure on prices.
  4. mattboyslim
    mattboyslim
    Mar 21, 2005
    104
    +4
    Would probably be able to stretch to about £300 for an amp. Is the denon 3910 better than the 2910, or is just better because of price?
