Help and advice needed
Discussion in 'Satellite TV, Sky TV & FreeSat' started by ojlewis2000, Mar 18, 2006.
  1. ojlewis2000
    ojlewis2000
    Dec 26, 2005
    50
    I have sky multiroom with one Sky + pace box upstairs (which works absolutely fine), and a normal sky box.
    However, this is were the problem lies. I have one of those fairly old Grundig silver boxes and whenver I tune into skysports or any other channels that are pay per view type (i.e. encrypted) I get a "No Satellite Signal Being Received" for about 20 seconds. Sometimes, if I have been watching BBC or ITV for a while, it then takes about ten minutes for it to tune in.
    I guess it is the box that is dying???
    Thanks for your help in advance.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    It could be electrolytic capacitors drying out in the power supply - a known issue on the old Grundig boxes after some usage.
    Satcure may do a repair kit - but there could also be other things wrong by now.
    You could also try a forced reboot and/or software upgrade to see if either makes any difference.
    Chris Muriel, Manchester
  3. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    or plenty of sky boxes for sale on ebay at giveaway prices
