help and advice needed (hd for hd )
Discussion in 'Xbox Forums' started by eddy no1, Jan 13, 2008.
  1. eddy no1
    eddy no1
    Jun 15, 2003
    305
    28
    ipswich
    +28
    ive got an external hd plugged in via usb into my 360 works ok im after putting bigger (hd) files over so the fat32 format became a problem (4gb limit) , i re formated using macdrive (hsf+) worked ok for a while but now if freezes up my pc and wont let me write to its even crashed my pc once so after many attempts and 2 more reformats im after networking a hard drive ive got the bt homehub with a spare usb port , is it possible for the 360 to read the files from the hd if its networked and is the whole file format still an issue and which is best any one got any input for me as to the best option ?
    any help is most needed this is a path im 100% new to ,ive seached the forum and just going round and round
    My set up. --vista premium --by home hub --- xbox 360 ,wired
  2. eddy no1
    eddy no1
    Jun 15, 2003
    305
    28
    ipswich
    +28
    after more seaching a device called the buffalo linkstation has come up anyone know if this is the answer to my prayers ?
