Help an idiot
Discussion in 'TVs' started by UKChap, Jul 29, 2005.
  1. UKChap
    UKChap
    I going to buy a HD ready Plasma and a Panasonic Home Cinema system with the DVD player etc. Will the the Home Cinema system be useless when HD comes in and won't work on Sky HD programs or play HD DVD's???
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If you're particularly worried about HD, best to wait about a year. HD ready plasmas are only just arriving, and the longer you wait, the cheaper they will be. Existing DVD players will not play many HD disks. In my opinion, it will be at least 5 years before HDTV becomes commonplace in the UK.
  3. UKChap
    UKChap
    The TV im buying will be okay but the Home Cinema kit will be useless I assume and won't work on Sky HD progs & HD DVD's...can you get HD ready Home Cinema systems??
  4. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,189
    Somewhere being wrong but staying strong
    +5,340
    I imagine your cinema system will be used to process 5.1 surround sound which will still be the standard with HD pictures. No HD playback devices apart from PC's are available as yet so what you have should be fine.
  5. UKChap
    UKChap
    thanks very much :thumbsup:
