Help! Amp interfering with TV!!
Discussion in 'AV Receivers & Amplifiers' started by Blenky, Oct 23, 2001.
  1. Blenky
    Blenky
    Jul 27, 2000
    526
    46
    Hove, England
    +162
    My amp (Yam RX-V795aRDS) is on a shelf directly under my Philips WS TV. It is separated from the TV by about 3 inches and a glass top the TV sits on.
    Recently I have noticed the amp interferes with the TV picture. It is hardly noticeable when watching TV or R2/4 DVDs. However when I play R1 DVDs there is a noticeable flicker in the bottom left hand corner of the screen which disappears when I turn the amp off. If I turn the amp on/off I sometimes get a discoloration on the screen at the bottom left. This I can get rid of by again turning the amp on/off a few times. Seems almost like a degauss!
    I don’t know if the fault is with the TV or the amp.
    Apart from moving the amp – which would be very difficult with my current set up - is there anything I can put between the TV and the amp that would filter out the interference?
    Any help/advice would be appreciated!
  2. Dave Taylor
    Dave Taylor
    Oct 7, 2001
    286
    High Wycombe, Bucks
    +17
    Nothing is faulty, it will be the magnetic field produced by the amplifiers mains transformer. A sheet of 2 or 3 mm steel will help or mu-metal which is very expensive. I you can find more room then move the amplifier further away. It will help
    You should do something otherwise you could permanently effect you picture.
    Hope that helps
    [ 24-10-2001: Message edited by: Dave Taylor ]
