help/advice on my samsung ht-x30t
Discussion in 'Home Cinema Buying & Building' started by jonax00, Jun 16, 2008.
  1. jonax00
    jonax00
    Jun 16, 2008
    2
    hello everyone, :)
    i've searched the forums, sadly i didn't find a similar problem or solution to my problem... maybe this is just a simple one. :rolleyes:
    i have a new samsung ht-x30t model :), i played my movies using my usb flash drive.
    i wanna try playing a HD movie, so i bought a 8gb flash drive, unfortunately, a HD movie i wanna copy to my usb doesn't fit (file too large):(. so i split the movie into 2 parts and copied the 1st part to my usb(3.9GB), but when i plugged it in the unit and selected the usb, the machine doesn't play the file & just skips the movie file to play another dvdrip file(700mb avi). :confused:
    this is aside from the fact the machine couldn't play certain movie files(codec not supported), but the movie file i wanna watch does not have any errors like the above mentioned, the machine just plays the next one on the list.:rolleyes: this after "reading" the file for a few seconds...
    whew... :oops:sorry for the mile long story/explanation...
    any suggestions/comments/ideas/solutions and tips on how to work around this problem are much welcomed! :lease:
    my thanx to you for reading! :thumbsup: and your help too!;)
  2. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Samsung HT-X30 cannot play HD DVDs. It can only play upscaled SD DVDs. What file structure did you use when you trimmed the movie down to 3.9Gb?
  3. jonax00
    jonax00
    Jun 16, 2008
    2
    ahhh! i see... so that's why it just skips the file and play the next one. :lesson:
    what a file structure? :confused: sorry, i'm not familiar with the lingo... is it the .avi or the divx? how would i know sir? :rolleyes:
    anyways, i've worked around the problem... i burned it in a hard disk folder - converting the movie to a dvd file (video_ts), and instead of burning to a blank dvd disk, i copied the folder to my flash drive - works beautifully! :cool: although not at full screen, but hey, at least it's more crisp than the normal dvdrip i have, right? :D
    thanx for the reply sir. much appreciated! :smashin:
