Help! Advice needed...
Discussion in 'AV Receivers & Amplifiers' started by hjEx, Jun 25, 2001.
  1. hjEx
    hjEx
    Any help appreciated
    I am the proud owner of a Sony VPL-VW10HT video projector and now it´s time to invest in sound.
    I have about £4000 to spend. (Speakers, amplifier and cables)
    I have a dedicated cinema room with about 50 m2. (10 x 5 metres)
    Music is not a crucial factor in my decision (95% cinema, 5% music)
    I would like 7.1 sound so I considered two choices:
    System 1:
    1 Denon AVC-1SE
    Jamo THX System 2 - D 6PTX plus one pair of D 6SUR for 7.1 sound.
    System 2:
    1 Denon 3801
    1 pair of B&W DM603 S2 (front channel)
    1 B&W LCR6 (centre channel)
    2 pairs of B&W DM602 S2 (surround and surround back channels)
    2 B&W ASW1000 subwoofers
    After reading Audio Perfectionist Issue #1 not sure about THX certification
    nullAVS Forum
    System 2 about £500 cheaper
    So what do you think of this two choices?
    Any other option?
    Other system?
    Please any comment highly appreciated.
  2. Arthur.S
    Arthur.S
    Do you have anywhere that can audition the systems for you? I know you mentioned cables, but be prepared for the extra cost of decent cabling, as the room is quite large.
  3. hjEx
    hjEx
    That is one of the problems Arthur.
    I can´t find a single place whith this systems to try, just separates.
    One place has the amplifier other the fronts other the center...
  4. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    hjEx,
    It's difficult to put this but I really don't think you will be disappointed with either system. The A1SE is an incredible amp but the 3801 teamed with the B&W's should sound superb.
    Tough call. I would personally buy the A1SE and create a rock solid foundation for your system, but the choice is yours.
    Arthur.S
    Did you know that HCC are on the lookout now for d.i.y. home cinema setups? Thought you might be interested.
    Mark
  5. Arthur.S
    Arthur.S
    Do you know somewhere that has both amps? At least you could hear them both, even if not with the speakers that you want to partner them with. Same goes for the speakers. If not the full set, then maybe centre V centre, etc? If that's still not possible, then you've got a nice problem. :)
    The first system, would probably have the edge. Although the B&Ws are more musical, I think the AVC-1SE would cancel that advantage out. The Jamo THX system has a terrific rep. Confess though, that I've not heard them. I do know, that you won't be disappointed in either system!
    Mark,
    I did send details in to HCC, but never heard anything back. IMHO the first reader's DIY HC should be Fulabeers. Mine is more a room 'makeover'. His really does look the Biz. Whatever he's doing for a living, IMO he should stop now & pursue a career in HC installs! :)
  6. hjEx
    hjEx
    Thanks for your advices.
    No Arthur I have no place to make a side by side comparison of the two amplifiers.
    When you say that Jamo THX System has a terrific rep you meant good or bad?
    I know that B&W are more musical but my main concern about Jamo is if the 80HZ low range is enough to have enough bass in center and front channels even if the bass under 80Hz is routed to subwoofer.
    A friend of mine has a Sony system (SS-X7 - 35Hz to 25.000 Hz - front and SS-TX7 center and surronds SA-WX90 sub with Sony STR 940)and doesnt matter choosing large or small in speakers I always feel that voices and music has always little bass and lots of mids and highs and then you feel all the transition to sub that is very powerfull, sound seems and feels disconected.)
    In the other hand my room will be hometheater dedicated and so I think that dipoles will give more envolvement and difuse sound because I dont like very localized surround sounds.
    With B&W DM 602 S2 will this happen?
  7. hjEx
    hjEx
    If I stretch a little and go for AVC-A1SE with the B&W will sound be improved over the Jamo THX System 2.
    As my primary target will be movies are the B&W a better choice over Jamo (THX Ultra certification, dipoles surrounds)?
  8. Arthur.S
    Arthur.S
    hjex,
    Remember, I can only give you my opinion. I don't own any of the equipment that you mention. Are there any reviews (maybe on this site) that you can check out first?
    By the way, 'terric rep' means good. :)
    I don't have 7.1, but I would think that 'localisation' isn't as much a problem as with 5.1?
  9. hjEx
    hjEx
    Yes I know Arthur.S that it is your opinion and I apreciate it.
    But check this article outHome Theater Magazine
  10. Arthur.S
    Arthur.S
    Terrific review. A shame that they didn't include bi-poles though. :(
