OK, so SMART says my hard disk is dying, so does Windoes Vista so I have brought a new one. My existing hard drive has 3 partitions. What I need to know is, Windows says it will image my existing drive to the new drive. Does this mean I need to put 3 partions on my new drive or will it do that automatically? I have assumed it will copy all my software as well etc. Does Windows do this well or should I get some software to do this. What I want to be able to do it put the new drive it, let something copy it all over to the new drive to the old. Shut down then re-start using only the new drive and its all exactly as it is now except not warning me its going to die.
Stephen
Stephen
