Help & Advice needed please.
Discussion in 'AV Receivers & Amplifiers' started by Mark P, Feb 16, 2001.
  1. Mark P
    Mark P
    pretty new to home cinema, at present i have a tosh 32"wide screen tv and sd3107 dvd player, jvc vcr and a grundig sky digibox. i now feel its time to upgrade, or should i say add, a bit of bite and boom into the sound system. to many this may sound like a silly question, but remember i'm still a bit of a homecinema virgin, or should i say havn't gone all the way yet. (IN THE AV DEPARTMENT!) What im trying to say is what is the difference between a amplifier and a processor. Does it matter which one i buy?, or do i need both? I think i will be buying the mission fs speaker system, so the question really is, "with the equipment that i already have what else do i need for a half decent set-up?". any help will be much appreciated.When i go into my local sevenoaks to try out some equipment, i don't want to sound like the novice i am. look foward to some replys
    Mark P
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,505
    WEST MIDLANDS
    +1,417
    Mark
    You need an amplifier , processors need seperate power amps to drive the speakers, and are generally quite expensive options.
    My advise would be to go for a good all in one AV AMP like Yamaha,Denon,Pioneer or Sony any good dealer will be able to advise you.
    Happy viewing Carl.
    The names BUELLER...FERRIS BUELLER.
  3. calibos
    calibos
    Aug 4, 2000
    940
    Ireland
    +33
    Mark
    A processor is basically a box with all the electronics that decode the Dolby Pro Logic, Dolby Digital or Dts soundtrack but without its own amplification. You would need to buy a separate amp/s which would amplify the decoded soundtrack and send it to the speakers. As the previous poster said, these are usually more expensive than an all in one unit. A Home-Cinema amp has the processor or decoders as they are called built in as well as amplification. You may come across something called a reciever. This is a home-cinema amp with a built in RDS radio.
    Another option that may be open to you is that if you have a DVD player with a built in decoder (I don't know if your model does. See if there are audio outputs around the back marked Front-Left, Front-Right, Centre, Rear-Left, Rear-Right and Subwoofer.) you could use a couple of old stereo amps you might have lying around or buy a second hand Dolby Pro Logic Amp with 5 channel input. Sound quality wise however this would be the least preferable choice with the best price/performance option being a new Amp or Reciever and the expensive/high performance option being a processor with quality amplification.
    Don't be a don't be.......Be a do be!
    HomePage - http://gofree.indigo.ie/~deveney
