Help, advice for sky and ?TIVO
Discussion in 'Sky Digital TV Forum' started by Doctor_AB, Aug 23, 2005.
  1. Doctor_AB
    Doctor_AB
    Aug 30, 2003
    2,445
    48
    Buckinghamshire
    +79
    I have Sky+ and mirror sub for my dad with standard sky. Can I buy a standard sky+ box and get him all Sky+ features or can I plug in a hard drive recorder or TIVO type device? Thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You can swap the digibox for a SKY+ (it will need the extra LNB feed) and the SKY+ sub will be included in your multiroom subscription so no extra per month to pay.
    You can of course connect any external recording device to a digibox, the facilites and ease of use being down to the individual recorders specs.
  3. Cyril
    Cyril
    Jul 20, 2005
    1,113
    48
    +39
    Each Sky+ box will need 2 LNB feeds.
    You can add TiVo to control a Sky+ box, but things get complicated as both will want to change channels at the same time if you want Sky+ to record two things at a time.
    So you have to be careful when you want TiVo to record something or Sky+ to record.You could disable TiVos' channel change control of Sky+ though.
    This is not a problem if you only use Sky+ to record one channel, as it will switch to the second tuner if it gets a channel change request from TiVo.
    Probably easier to have two Sky+ boxes and another Sky box which is solely controlled by TiVo so you get the best of both worlds.
  4. Doctor_AB
    Doctor_AB
    Aug 30, 2003
    2,445
    48
    Buckinghamshire
    +79
    thanks chaps. If i decide to keep simple sky box can you recommend somewhere to start to narrow down choice of external recording devices.
  5. Cyril
    Cyril
    Jul 20, 2005
    1,113
    48
    +39
    For best flexibility and PVR features, nothing beats TiVo.
    However there are plenty of cheaper DVD and Hard disk recorders around.
    Just make sure it records RGB for good quality.
    Check this forum, www.digitalspy.com and www.tivocommunity.com.
