Help adding device required
Discussion in 'Computer Components' started by gwladok5, Jan 8, 2012.
  1. gwladok5
    gwladok5
    Dec 2, 2004
    193
    +3
    I have an Asus P5ND motherboard
    I currently have all 4 SATA slots occupied with 2 x HDD & 2 x blu-ray read/writers
    I have 2 x IDE mobile racks in master/slave configuration connected to the PRI-IDE slot
    I wish to add a further SATA mobile rack & have purchased the Startechcom PATA2SATA2 SATA/IDE converter to connect via a PCI bridge currently occupying the PCI2 slot on the motherboard
    However, the PC does not recognise this setup
    Am I right that this motherboard should accept this additional device?
    regards
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    23,931
    Poole
    +9,302
    Have you installed the software/device driver?
    Non standard controllers are not recognised automatically.
  3. gwladok5
    gwladok5
    Dec 2, 2004
    193
    +3
    Hi Trollslayer
    The StarTechCom site claims no software/drivers required
    None came with it
  4. gwladok5
    gwladok5
    Dec 2, 2004
    193
    +3
    All sorted now
    I've found a 3rd IDE rack & have IDE connected to the PCI bridge
    Worked 1st time so stuff the converter until another time!
    Or future m/board upgrade
