Help - Accidentally erased HDD of Panasonic DMR-E100H
Discussion in 'Blu-ray & DVD Players & Recorders' started by Harry H, Apr 21, 2005.
  1. Harry H
    Harry H
    Apr 21, 2005
    29
    In trying to format a new DVD-RAM it looks like I've erased the entire contents of my HDD. I'm not exactly sure how it happened, and want to be sure that it has gone for ever. (Ironically I was just about to make copies to discs of this material never likely to be broadcast again.) Is there any way I can access the HDD and check (like one can on a computer), and if the recordings are still there recover them?
    Thanks.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    No, i'm afraid they're lost forever.
    'never likely to be brodacs again' ?
    I found that hard to believe by today's 'standard' of TV scheduling.
    What were they?
  3. Harry H
    Harry H
    Apr 21, 2005
    29
    Thanks for your interest Kevo.
    They were the BBC4 broadcasts from Shakespeare's Globe of 'Richard II' and 'Measure for Measure'. Although that channel seems to repeat a lot of programmes (like 3 times a night sometimes!) these long programmes may not get scheduled again (they have both been repeated once, shortly after their initial broadcast).
    Because they have a minority audience the BBC are unlikely to release them onto DVD, and The Globe say the cost of the rights would be too prohibitive for them.
  4. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    I'm alway wary when making deletions on my E100 and have got in the habit of always glancing at the menu first to make sure that i'm on DVD RAM and not HDD especially when formatting.
    The newer range (E85/95) are much more clearer on what mode you are in as they brightly colour code each on the main fascia display.
    I just know it's only a matter of time when I slip up!
    This is all of no use to and sorry I can't be of any help.
    It may be worth asking (in the right forum) to see if anybody has recorded these programmes and send you a copy.
  5. Harry H
    Harry H
    Apr 21, 2005
    29
    What is frustrating is that Format takes no notice of the individual Programme Protection, which of course I had set up. It doesn't even prompt to say that it will erase what is 'protected'!
    Oh well...it won't happen to me again!
  6. Tocsin
    Tocsin
    Mar 4, 2005
    35
    Long shot, but it may be worth contacting one of the PC data recovery companies, if you haven't already overwritten the hard disc with new recordings. They are very expensive though!
  7. jinkzzz
    jinkzzz
    I did exactly the same thing and could not retrieve the full disc of programs I had. I even took the hdd out of the E100 and tried to read it in a Windows XP based PC. The disc was recognised by the bios, but not the way it was formatted. It's obviously not an NTFS or FAT system and may be proprietary Panasonic format. Does anybody know?
  8. greyhorse
    greyhorse
    Apr 16, 2005
    447
    its not xp format partions, took a drive out to try and clone it to a larger drive.
    Didnt work.
  9. willemb
    willemb
    May be its a LINUX format. I don't expect Panasonic to set up a proprietary format since this requires a lot of software to develop and maintain. Moreover for each simple read- write- or format task they would have to write their own routines. Yet as the recorder needs some sort of operating system and basic LINUX has a very small size, it is quite possible that they used a LINUX core. Has somebody tried this already ?
    WVB
