I am in the market for a plasma and need some advice.
I have a fairly low budget of maximum £2500 and that has to cover the screen, wallmount and some half decent cabling.
I know I cant expect to much for this sort of money, but hopefully some of you guys will know where I should start.
After searching through this forum I cant seem to find much advice on cheap plasmas and most of the model numbers for sub £2000 plasmas turn up a blank on the search engine.
So, my question is. What can I expect for that sort of money?
Where should I go to get it?
Will I be able to get a screen without a fan for that money?
Should I scrub round it, get cheap CRT and save til I can get the 63"NEC ( which will be a long, long time!!!! )
