Help a Newbie!!
Discussion in 'Plasma TVs Forum' started by dvdrkk, Jan 10, 2005.
  1. dvdrkk
    dvdrkk
    Hi all,
    I've been looking around this forum for some time and have decided that its time to ditch my tosh 32" crt and take the Plasma Plunge.
    Basically i'm looking for any help or advice.
    I'm thinking of going for either the panasonic pw6 or pw7 as PQ is the thing i'm looking for. What is the difference between these two sets as they seem to have the same features?
    I'll also need something to handle the audio. Budget is fairly tight at aound £2300 for both the Plasma and AV reciever. I'l be running Sky + through it along with a chipped pinoeer565 dvd player and an xbox. what would be the best way to connect it up etc? Ideally i'd like something to get me off the ground with room for upgrade in the future..
    Thanks for any help!
    Kev
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
