Help a newbie out...
Discussion in 'Home Cinema Speakers' started by bobdroopy, Sep 7, 2005.
  1. bobdroopy
    bobdroopy
    Hey guys,
    I'm pretty bad with the audio department in my theater. Heres my situation: I've got a projection screen in my room and a average 'home theater in a box' to go with it. My question is, is there a single speaker I can buy to replace my center speaker. Any models or brands you guys recommend, thanks alot!
  2. bentleg
    bentleg
    Aug 16, 2004
    330
    Notts
    +6
    You will find almost every speaker manufacturer has a centre speaker in there product line up witch are normally available as a single unit.
    If you look at "mordaunt short MS 304" quite a small speaker and I think it wont look out of place with the rest of your theatre in a box set up.
    Hope this helps
