Help a confused Arcam owner...!
Discussion in 'Hi-Fi Stereo Systems & Separates' started by GW43, Feb 27, 2005.
Tags:
  1. GW43
    GW43
    Feb 27, 2005
    1,662
    63
    Out of my mind on dope and speed
    +169
    I currenly have an Arcam Alpha 7SE, and whilst very happy with it, a recent change in speakers (Tannoy 605 to Monitor Audio Silver S1) has given me a lot more detail and clarity. I'm beginning to wonder if a similar improvement could be had by upgrading my CD player (Amp is an Arcam Alpha 5 Plus). I have three options (possibly more) within budget and WAF.
    Firstly, I could go down the route of upgrading the 7SE to the CD82 - I understand this is still available.
    Secondly, I could get the 7SE re-clocked by someone like Trichord
    Thirdly, I could bung the 7SE on E-Bay and use the cash towards a new CD73.
    The final option has the merit of giving me a new transport - the 7SE has had quite a bit of use, but has never let me down.
    Any thoughts/alternative suggestions?
  2. dfindlay
    dfindlay
    Jun 3, 2004
    Ottawa, Ontario
    In my experience - and I've read this from learned audiophiles as well - upgrading your source components is the single best move you can make to improve the performance of your system. I recently upgraded my CD and DVD players and the difference was dramatic.
  3. arcticpollen
    arcticpollen
    Feb 22, 2005
    214
    28
    Horsham - West Sussex
    +21
    I have to say that normally I would look at the source components first but is the amp not getting a bit long in the tooth?
    I had a quick glance at a couple of dealers' sites on prices for a CD82 and you are probably looking at anything up to £500.
    I will shortly be putting an Alpha 8 integrated, an Alpha 8P and an Alpha 8SE CD player in the classifieds following a more "wife friendly" purchase of an AVR250 to replace a large stack of kit.
    I seem to remember that most Monitor Audio speakers are bi-wirable. Can I suggest a "4th way"?
  4. GW43
    GW43
    Feb 27, 2005
    1,662
    63
    +169
    I moved away from bi-wiring a while ago - the old Tannoys gained a new lease of life when I reverted to a cheap single wire, as opposed to the bi-wire cable I had been using. They became more detailed and dynamic, so I held on to them for a while longer. Bi-wiring is snake oil selling as far as I'm concerned.
    I'm not a techie, but I don't believe there have been radical developments in amp technology in the last ten years (other than multi channel, which I am not interested in). The amp still sounds fine, there are no unpleasant noises from the volume control or source selection, and it goes loud enough!
    I'm also not a subscriber to the "new is necessarily better" school of thought - although "newer can be different", I would agree with. New products (in any field) are often released simply to placate dealers, refresh the sales effort and boost company profile - I work in marketing, so I know what happens!
    All this makes me sound like a Luddite - I'm not, but given a straight choice I'd rather spend £400 on CDs than on hardware.
    I'm just looking for a bit of advice without there being a vested interest at the end of it. A dealer I spoke to on the matter of the best option for the Alpha 7SE immediately plumped for the CD73 as the choice to go for - that's the one that puts the most on his revenue figures and probably gives the best profit.
  5. Timmy C
    Timmy C
    Oct 10, 2003
    5,652
    +574
    Have you considered a second hand alpha 9 cd player? I just replaced my 7se with a 9 on my second system with noticable improvements.
    I would agree with arcticpollen though, I'm sure an amp upgrade would be well worth looking into.
