Help- 43 rp or wait and get 36 crt
Discussion in 'General TV Discussions Forum' started by S600BYC, Oct 7, 2003.
  1. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    Looking for everbodys opinions here so anything at all is a bonus!
    Thinking about a panasonic pd30 (36 inch) but have seen very good deals on the toshiba RP 42 , 23 model and has got me wondering what would be best? I watch a lot of football, lot of movies and freeview tv and some movies(dvd). What do people think when i add in there is nearly a £800 in diference.
    I currently have a 28 inch jvc flatscreen (what tv winner couple of years ago) and am looking for an overall increase in screen size without a loss of detail as the picture is very good. Room size is 5.5m x 5.5m. Thanks for your time everybody, Scott.
  2. davej
    davej
    Jul 31, 2003
    85
    Sunderland
    As a regular football viewer I had a horrendous time with the panny 36pd30, going through three before giving up. One of the pd30's flaws is a "dirty screen" effect which is unnoticeable when watching most TV but highlighted when watching footy (slow pans across the pitch). In common with a lot of TVs of that size it also highlighted digital artefacts with sport.
    Maybe I'm just bitter and twisted, ok, I am bitter and twisted, I wouldn't recommend the set for a sports viewer at all.
  3. S600BYC
    S600BYC
    Jul 1, 2003
    59
    john o'groats!
    any more opinions?
  4. nathan_silly
    nathan_silly
    I had a Pansonic 28" widescreen, now a 42" Toshiba CRT RP. I can recommend one. However check for 50hz PAL flicker (on the standard 50hz set- 42PW23P) also check if you can see any 100hz artifacts.
    I've seen 32" & 36" TV's with terrible geometry. This can be corrected on a CRT RP.
