Help, £2600 to spend!
Discussion in 'Plasma TVs Forum' started by P13TR0, Aug 8, 2004.
  1. P13TR0
    P13TR0
    Hi... I have £2600 to spend on a new Plasma (42"). There are no shops near me with decent monitors/ TV's on display, so I really need some good advice. I have been looking at the following:
    Fujitsu P42VHA30 ES
    Hitachi 42PD5200
    Panasonic TH-42PW6B
    Panasonic TH42PE30B (£2699.69 in Comet...use for a JL price match)
    or should I wait for the Panasonic TH-42PHD7? either to buy or to see the price of the Panasonic TH-42PW6B come down?
    By the time I add everything to the Panasonic TH-42PW6B it came to £2553.64 at AV- Sales. Is the TH-42PW6B as good or better than the TH-42PW6B.
    I am really at a loss with this descision. If you have any suggestions, opinions or advice, I would love to hear it!
    P.S I will be using the TV or monitor to watch TV, hook up to a PS2, watch DVD's and sometimes hook up to my PC.
