Hello guy's nead a bit of help with lcd testing
Discussion in 'LCD & LED LCD TVs Forum' started by SLIM, Dec 17, 2004.
Tags:
  1. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    Hi guys nead a bit of help i am getting a LG. RZ20LA70 lcd screen i think its that one anyway. :oops: And i would like to know if anyone knows of any softwear to down load to test the screen for dead pix's. Any help would be nice thanks.
  2. aspender
    aspender
    Nov 22, 2004
    44
    Southampton
    You don't need any software, you just need to get up close to your display.
    Dead pixels are either stuck off or on, and therefore may be black, blue red or green. In order to fully determine, you'll need to ideally display an entirely white, or red and blue picture. If you have a PC linked up to your display you can do this easily with your desktop background.
    If not, then something like the Digital Video Essentials DVD has test patterns of solid colour.
    Be warned however that from a normal viewing distance any dead pixels you have are likely to go unnoticed. If you get close up and find any, they may bug your forever! If you are planning on using the display as a computer monitor you might care more than if it's just for TV/DVD use.
  3. SLIM
    SLIM
    Jan 1, 2004
    1,364
    38
    +17
    THANKS dude its going to be only for the pc & xbox but if it dont look to hot then ill use it just for sky and dvd's.
    PS i dont play games on my PC any more i use it for backing up and looking around on the net
