Hello. Finally completed Home theater Check it out
Discussion in 'Members DIY Home Cinema Showcases' started by whitewolf, Aug 4, 2006.
  1. whitewolf
    whitewolf
    Oct 15, 2004
    285
    16
    Today i got my new trolley customized according to my needs. checked the power cables aand all and just installed my subwoofer. Take a look:
    My setup is Fronts are 205 Kef
    Center is 202c
    Rear are XQ5
    Woofer is Rel 505
    powered by :
    Arcam AV8 Processor
    Arcam FMJ P1 X 3 for fronts and Center
    And ARcam FMJ P35X 1 for Rears
    Dvd is Marantz 9500.
    Here are a couple of things u guys can help me with apart from your comments for my system:
    1. Comments on the system
    2. In my AV8 processor i have mentioned the following settings. Fronts as small center as small rears as small. Subwoofer as present and set to 80 cross frequency. is that ok ?
    3. On the subwoofer there is a knob for freqency which goes from 25-100. thats on 12 o clock i think that will work as 80 since its in the processor but i am not sure ?
    4. For my woofer lv i have chosen to keep it at around 68-70 volume is that ok or is it too hi? there is a volume knob in the woofer . my vendor said that he keeps in on 50 as default but its up to me so is 70-68 ok ?
    5. Lastly i have mentioned the distance for my fronts and subwoofer . all are at 22 Feet distance . so 22Feet for all from my listening position. As for my rears they are just 1 feet or 0.5 feet away. so mentioned that. is that ok ?
    Thanks for reading hope u give some good comments in numeric order.:)
  2. misae
    misae
    Dec 19, 2004
    1,244
    Derby
    +64
    Wow I absolutely love your floor!
  3. whitewolf
    whitewolf
    Oct 15, 2004
    285
    16
    Thanks anyone else
  4. John 1987
    John 1987
    May 25, 2005
    1,195
    +240
    Stunning set-up, love the speakers and the arcam equipment is amazing.
  5. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Floor is nice but I dont know if it will help with the quality of the sound. I would be tempted to get a thicker rug for the middle of your room.:hiya:
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Congratulations Whitewolf, following some fairly lengthy threads here a few years ago I hope you're happy with it all. :)
  7. misae
    misae
    Dec 19, 2004
    1,244
    Derby
    +64
    It looks like you have some sort of furniture that is going to be blocking the path of the sound from the front to the listening position. Not very clear on the 2nd pic.. and those pics on the wall I take it are you and the missus?
  8. Dynaudio Desire
    Dynaudio Desire
    Dec 8, 2005
    1,293
    Bury st. edmunds
    +57
    :eek: Kef 205's.....*drools*....."ggguuuhhhhh"
    That is a stunning setup!!
  9. whitewolf
    whitewolf
    Oct 15, 2004
    285
    16
    THanks a lot all of u. Yes i did research a couple years ago and finally its complete :)
    yes thats me and my missus :)
    and yes some way is blocked but its ok i guess its not all blocked and cant help clear it :)
    morever anyone wants to answer the questions
  10. Carl Stock
    Carl Stock
    Jan 29, 2004
    743
    46
    +109
    Lovely. :)
  11. whitewolf
    whitewolf
    Oct 15, 2004
    285
    16
    As u all know that My Kef 205 are powered my Arcam p1 monoblocks which give a power rating of 170. Kef 205 are triwirable and triampable. Now since i have a p35 with me also which is able to give 100 watts per channel to 2 speakers seperately. I was thinking what will happen if i can connect that p35 which is currenly powering my xq5 rears to my Kef 205 bi amping the kef205. how much power will then the Kef 205 be running at and how much quality difference will there be.
    I think rather than buying a 300 watts mono amp for the kef205 if i can get them the same power through bi amping then it will be a lot cheaper then a stand alone 300 watts amp.
  12. recruit
    recruit
    Moved to members Home Cinema Gallery :thumbsup: and great setup BTW.
  13. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    I'd leave the sub freq at 100%, and set the amp to 80Hz.
    I've mission pair of 775e front, pair of 773e surround and pair of 773e centre rears, 77c1 centre, velodyne cht-10.....all speakers set to small.
    Bass should transition between mains and sub seamlessly, I've a test disc somewhere...it does a freq sweep tone.
    Before we moved, I had rear floorstanders either side of setee, sounded OK, but better when I turned them in, so they went up on the walls pointing towards listening position...:eek: (no floorspace then)
    :hiya:
  14. whitewolf
    whitewolf
    Oct 15, 2004
    285
    16
    I rather found the Fronts and Rear to sound better when kept to Large. what about the bi amping thing. any suggestions ?
