Lyrica
Hi folks!
Thanks to your help (thanks again @Gasp3621 and @StefanBFC
) I got and setup an Arendal 1961 1S subwoofer and it has vastly improved our movie watching experience.
I'm now itching to open up the vertical dimension with height speakers.
I initially considered in ceiling speakers but after reading a lot about height speaker setup I'm leaning towards a more auro3D-ish configuration (30º angle?) which if I understood correctly would also work well for Atmos. That would also allow me to avoid making 6" holes on the ceiling.
I have a set of 4 wharfedale 220s and a 220c. I could use my Denon 1400h as 5.1.2, using my PC connected to it as the media player and I'm hoping to eventually upgrade the receiver, ideally to the Denon 4700h (w/ eARC, Auromatic and able to amplify 5.1.4) and to 4 height speakers.
Thanks for your help
- How important is it to match the general sound of the other speakers?
- How critical is the angle? With the speakers on the wall but close to the ceiling, 24-29º would be the ideal angles to target the main listening position. Should I incline the speakers further to reach from 21-22º (Klipsch or XTZ for instance) or 25º (Alteco) closer to 30º?
- Should I go with the Wharfedale d300 3d? It doesn't seem to be a good value at the prices I found. For a little more (less than 600€ for four), I'm under the impression that the XTZ S2 or the Dali Alteco-C1 would be better options. Which of these should I get? Which one would be a better match for the Wharfedale 220s?
- I also found the Klipsch R-41SA with a little discount (600€ for four) but couldn't find much about them... Are they any good? would they sound very different from the Wharfedale 220s?
- I also added Monitor Audio, the SVS Prime Elevation and Arendal 1961 speakers, but they are quite out of budget, so I would rather prefer not to go that route.
- Also, even if I so very briefly considered it
, I'm not willing to buy and place Wharfedale 220s as height speakers.
