Height Question
john dillinger
hey gents - if your planning on setting ur tv just above ur entertainment center and your viewing from a couch - arent you losing the optimum viewing angle /.?
zeppelino
Only with ips panels. Even then it’d have to be quite extreme.
VA ones you lose out from the side.
zeppelino
Only problem I can think of is neck strain. I have a 40” wall mounted in bedroom and it’s not an issue but it’s difficult to say definitively if it’ll be an issue for you.
John7
Centre of screen should be roughly eye level when seated, to avoid neck/eye strain.
john dillinger
yes but difficult if console is 32" tall and u want a sound bar on top of that - tv would be approx 36" off the floor - sitting on my couch I'm below center
Similar threads
