Height of Plasma/LCD screen?
Discussion in 'Plasma TVs Forum' started by ash, Jun 22, 2005.
  1. ash
    ash
    Jun 9, 2005
    11,221
    +395
    Whats best, a 0 degree or very low altitude from the eye, or high up on the wall.
    So at eye level when on the sofa or on the walll, were you have to constantly look up. Will you get neckaches? Or will your eyes suffer when looking upa ll the time?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    No fixed answer to this one, whatever is comfortable for you.
    FWIW, my 42" plasma is 900mm from the floor to the bottom of the screen, the middle of the screen is a little above eye height when sitting down.
    John
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Try the 'piece of paper' on the wall where you want it to be.
    The height depends on the distance you are sitting.
    I have mine approx. 1.1m to the bottom and do not find it is a problem.
  4. ash
    ash
    Jun 9, 2005
    11,221
    +395
    OKay thanks, what methods are there of putting a plasma on the wall without a wall bracket? As that takes space up, and i might move the tv.
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    No more nails :confused:
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    You can't put a 45kg plamsa on the wall without a bracket..
    Careful planning is what you need...
