Height of front 3 speakers
Discussion in 'Home Cinema Speakers' started by Triggaaar, Jul 20, 2004.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,167
    +1,183
    I've got to order some front stands, but I'm not sure which height to get. Could you give me some advice please Note - centre will be used with all music (Meridian Trifield) as well as movies.
    Listening position = 83 cm high (roughly ;))
    Centre speakers tweater = 58cm high, angled up.
    I have a choice whether to have Front L&R speakers
    a) the same as the centre (which would but good, but they'd all be a bit low)
    b) 68cm high (bit higher than centre, lower than listening position)
    c) 80cm high (closest to listening position, but higher than centre).
  2. 337GUS
    337GUS
    Nov 1, 2000
    756
    NE Scotland
    +39
