wardyworld
Established Member
- Joined
- Aug 10, 2013
- Messages
- 199
- Reaction score
- 79
- Points
- 88
I've nearly designed all of my 5.1.4 layout now. I'm using monitor audio iw460x speakers for LCR. I'm sitting 2.4m from the TV, which is centered to my MLP.
My centre speaker will only be 40cm from the floor (about 53cm from floor to middle of the speaker).
As they are in walls, there is no adjustment.
Question is, should I try and build an angle into the false wall to allow the speakers to point up towards my ears? My ears are about 110cm from the floor. With a quick protractor and string test, I'd need to build in an angle of around 10 to 15 degrees...
Cheers,
Wardyworld
Cheers,
Wardyworld
