Heeelp !!!!! Sky Going Funny
Discussion in 'Sky Digital TV Forum' started by Ghidorah, May 18, 2004.
  1. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hello,
    Can anyone help ? :lease:
    I have a normal Pace digi box and have got Tru Calling then Angel, And 24 then Cold Case on series link and also auto view.
    The first programs Tru calling and 24 come on ok, but when Angel or Cold Case starts I get no picture as soon as the programs start, up until the first ad break but i still have sound :( :( :(
    Hope someone can help
    Ghidorah :confused:
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I can get this at times, but it isnt my box because I change to another channel and it works ok then when i turn back, it doesnt work correctly again. Ive always just put it down to broadcasting issues
    ad
  3. Fernsehman
    Fernsehman
    What does "no picture" look like? Is it a blue screen or is there a message or what?
    Maybe it's a compatibility issue with your TV? Have you tried unplugging the Scart connector and plugging it back in when the fault occurs?
    Does it work with a different TV set?
    Does it work when you switch ove to RF instead of scart?
  4. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hi Guys,
    Thanks for replying
    Yes it is a blue screen but with sound, if I turn it off and back on the picture cames back.
    Also last week on Cold Case the picture disapeared at the start but came back on its own at the first ad break
    It has only started recently and has been on the same TV for ages and is the same on thed RF lead.
    Any ideas :lease:
    Ta
    Ghidorah
