HEEELLLPPP!!! Surround Sound Speaker Installation
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by 1stTimer, Feb 18, 2013.
  1. 1stTimer
    1stTimer
    Feb 18, 2013
    3
    Hi, I am new to the forum and somewhat of a novice when it comes to home cinema etc. I have been gifted some Pioneer S 11 Satellite speakers and surround sound system. I am looking to mount the speakers on the wall but have no idea what brackets to get and more to the point what the fitting is on the speaker.
    There is a screw at the top and then the wires go in at the bottom. I really dont have a clue what i am looking at and dont want to get the wrong brackets!! Any help would be much appreciated! :lease:
    Thanks,
  2. Jollyware1
    Jollyware1
    Feb 18, 2013
    3
    I have the same speakers as you do and THESE are the brackets I use.
  3. 1stTimer
    1stTimer
    Feb 18, 2013
    3
    Brilliant! Thanks....what are the speakers like? Any good?!
  4. 1stTimer
    1stTimer
    Feb 18, 2013
    3
    Oh and what about the centre speaker?! Is there a recommended bracket for that? Thanks!!
  5. Jollyware1
    Jollyware1
    Feb 18, 2013
    3
    I quite like the speakers and the sub is nice aswell.
    But I do have a small living room where the speakers are and they fill the space well.
    The centre speaker does not have any mounts that I can remember, but will have a look.
