Heeeellllpppp Pleeeeeassse!!!!!!!!!!!
Discussion in 'Computer Components' started by ged1985, Jan 15, 2008.
  1. ged1985
    ged1985
    HI EVERYONE THIS IS ABOUT MY 50TH FORUM TO POST ON AND IM STILL NO FURTHER FORWARD, PLEASE, HELP ME.
    I HAVE AN XBOX 360
    BELINEA 22" PC MONITOR
    XBOX 360 VGA CABLE
    VGA FROM XBOX 360 TO BACK OF MONITOR.
    HOWEVER THE GRAPHICS ARE POOR, LOOKS LIKE 420p -
    HOW DO I MAKE MY MONITOR RUN AT 720, OR 1080i ?
    PLEASE HELP ME, THANKS IN ADVANCE.
    GED
  2. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,077
    Northants
    +367
    you should turn caps lock off!
    have you tried searching the belina website for the manual for your model of monitor?
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You don't. You need to run it at a pc resolution, preumably this is a LCD, what's it's native res.
  4. ged1985
    ged1985
    Sorry about caps.
    Native resolution? I'm not sure on that, how do I find out?
    Its a Belinea 22" Monitor.
  5. ged1985
    ged1985
  6. Croatoan
    Croatoan
    Jan 7, 2008
    401
    28
    +59
    Go to the last blade and change the settings in the console option. Here you have the display resolution.
    Match the resolution to that of your monitor / tv.
    It always defaults to a low resolution when you change cable types until you tell it otherwise
    It wont run at 720p or 1080i as these are HDTV outputs.
    It will be more like 1280x720 for 720p or the native resolution of your panel.
  7. upallnight
    upallnight
    Jun 11, 2003
    1,837
    63
    watford
    +109
    I take it you have set the xbox360 to correct resolution?
    1280/ 720
  8. ged1985
    ged1985
    It doesnt have the option for a 1680 x 1050 resolution....
    Biggest it goes is ::
    1920 x 1080 which is to big.
    Before that is 1360 x 768
    I think its to do with the video output, think it is at 420 instead of 720i or 1080i??
    If this makes sense?
  9. Croatoan
    Croatoan
    Jan 7, 2008
    401
    28
    +59
    Its more likely 1280x720
    You will have to pick the next lowest widescreen resolution that your monitor can display
  10. ged1985
    ged1985
    Wierd thing is, I started up my xbox the other day, and the graphics were loads better than usual ?
    Thats how I realised that the graphics should be better than I was used to...but after restarting my xbox it went back to how it was before, so now I want to know how to get it back liek that and how it done it itself?
    its at 1024 x 768 at the moment
    what wud u reccomend i do?
    is it still at 420p or does that not come into play using the vga cable?
  11. ged1985
    ged1985
    Ive just noticed I changed it to 1024 x 768
    It looks loads better on the dashboard and as the game loads, but when I press start the on the menu to go to main menu inside fifa 08 - it seems to change and go all crappy?
    the fifa box states it needs 720 / 1080i/ 1080p
    but this was the game that looked loads better by itself the other day until i rebooted the console
  12. upallnight
    upallnight
    Jun 11, 2003
    1,837
    63
    watford
    +109
    set it to 1280x720 and it will be fine:thumbsup:
  13. ged1985
    ged1985
    any ideas
  14. abraxus
    abraxus
    Jun 6, 2006
    1,633
    63
    +216
    Set it to 1360 x 768.
