Heating Automation ??
Discussion in 'Smart Home, Climate Control & Security Forum' started by Spy, Feb 16, 2005.
  1. Spy
    Spy
    Jan 6, 2004
    3,168
    London
    +271
    The timer on my heating system has broken and rather than replace it with a similar model I was thinking of fitting an X10 version
    Looking through the various websites, I only seem to find X10 Thermostats - am I miising something ?
    Are there X10 heating timers ?
    By timer, I mean the type where you set the times the heating comes on and off
    Any help is appreciated
  2. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Heating automation is an interesting topic and one of the few areas of home automation that consistently gets high WAF! There are many different approaches and few commercial solutions - the most common of which is probably the Honeywell Smartfit.
    I am not aware of any X10 heating controllers but most of the home automation controllers that manage X10 provide the basic functionality.
    Take a look at the forum over at Automated Home (http://www.automatedhome.co.uk) - there is a specific area for Heating Control that also refers to various articles on automating central heating.
    I went for a home-built solution using a VIOM (www.phaedrusltd.co.uk) managed by my HA controller (Homeseer). This solution provides me with much greater timing control than I could ever get with a standard controller and the ability to control the heating through a browser or via a remote (IR or RF).
    A Netiom has recently been produced that has the same relay outputs as a VIOM (also from Phaedrus) but which can be directly controlled though a browser. There is also a product called the WebBrick (see http://www.o2m8.com) that provides input output control and a web interface. It would be an excellent solution if you just want a standalone solution.
    I hope this helps rather than confuses!
    BR
    David
  3. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I replaced my heating timer with an x10 appliance switch , I then use homeseer to do all the timer settings in conjunction with digimax thermostats to monitor the temperature. Gives huge flexibility but the cost of a dedicated hapc and buying all the necesary x10 stuff makes it an expensive option if heating is all your going to controll.
  4. Fartpants
    Fartpants
    http://www.automatedhome.co.uk/faq/index.php?sid=7288&aktion=artikel&rubrik=002&id=9&lang=en
    shows a very simple way to do it, I am going a bit further to tidy up the basic good idea, I have found the basic appliance module is in 2 halves, I am going to use two top halves through terminal block to conect it all up, and put it all in a nice box.
    I will do pictures, but the chap on that page has done a very good simple job to do for about £35 what others pay hundreds for.
