Heating advice
Discussion in 'General Chat' started by Mr Noble, Aug 2, 2012.
  1. Mr Noble
    Mr Noble
    Sep 28, 2008
    17,192
    Gateshead , Tyne & Wear
    +4,021
    So I woke up this morning went in the lounge and the place is like a sauna!
    Thermostat is set to off position, the boiler also set to off on the heating section
    Anyone got any ideas? I've turned the boiler off at the wall as the radiator seemed to be getting hotter.
  2. Andyh4324
    Andyh4324
    Dec 8, 2009
    1,602
    Bit of land next to the sea
    +319
    Have you got a combi? If so have you been running hot water?
    Perhaps the divertor valve is stuck or the motor is not working anymore. The heat might going into the heating rather than all into the water.
  3. Mr Noble
    Mr Noble
    Sep 28, 2008
    17,192
    +4,021
    Yeah combi boiler , only use hot water tap as and when needed.
    The boiler has been flareing up every hour or so as if to boil water for the last few weeks mostly at night
