Heated towel rail...
Discussion in 'General Chat' started by a l e x, Jul 20, 2015.
  1. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,698
    Finally got round to decorating the bathroom so will need to remove the towel rail...
    There's 2 valves on the bottom of it. One of them is a chrome one and it simply turns left and right. I'm assuming this is for temperature? The other one isn't the same. This one completely unscrews to reveal a screw. What the hell is this one for? Thought they were both the same!
  2. its_all_Greek
    its_all_Greek
    May 8, 2009
    4,792
    Nottingham
    +2,609
    Pics would help here.
    I had a similar thing on my old rads. The white bit is just a protective cover and the "screw" is the valve bit.
    Remember though...
    lefty lefty loosy loosy
    righty righty tighty tighty.
  3. DIYlady
    DIYlady
    Oct 13, 2009
    2,189
    146
    Ascot
    +2,046
    Balancing the system probably.
    If the right one is thermostatic then it controls according temperature, closing and opening appropriately. Otherwise it is just controlling flow which will indirectly affect the temperature
  4. nvingo
    nvingo
    Nov 29, 2007
    3,247
    Cambridgeshire
    +822
    It's to isolate the "radiator" so it can be removed without draining the whole system. Then you can change it, paint/decorate behind it, flush it with a hose or whatever. Then connect it back up and let the water back in.
  5. DarenD
    DarenD
    Jun 13, 2009
    3,778
    West Auckland
    +1,133
    Lefty loosely. Aye unless it's a reverse thread lol
