Heat Soak ?? I'm still confused !!
Discussion in 'Projectors, Screens & Video Processors' started by Fjorko, May 18, 2003.
Thread Status:
Not open for further replies.
  1. Fjorko
    Fjorko
    Apr 25, 2003
    510
    Port Elizabeth
    +24
    Can anyone please clarify whether Heat Soak will affect all LCD projectors at some stage during it's lifespan . . . ??
    Does this mean that at some stage the PQ will be so bad ( because of the heat soak ) that the projector will need replacing or a replacement of the optics ?
    I was hoping that i would just need to replace bulbs after the lamplife has reached it's end, but i never imagined that heat from the lamp can permanently damage the projector's lcd panels after long use . . .
    Anyone have facts about this ????
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Fjorko,
    Is this a repeat of this thread ??? Duplicate threads, when the issue is already under discussion in another thread.
    All LCD projectors ?? I don't think anyone can be that definitive....
    Have a read of the last pages of this thread, and check out the reference to Paul O Hales post concerning heat damage. This should answer your question.
    Sean G.
  3. Kramer
    Kramer
    Yep, duplicate thread - closing...
Thread Status:
