Heat Generated by Plasmas
Discussion in 'Plasma TVs' started by Ponty, Sep 25, 2005.
  1. Ponty
    Ponty
    Feb 15, 2005
    68
    Do all similarly sized plasmas generate the same amount of heat? They seem able to heat the room all by themselved....
    I'm concerned about how hot the room will get, especially during summer months.
    Ta
  2. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    I have panasonic screens and they don't generate much heat atall
  3. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    It varies a bit, but generally yes, they all get pretty hot. Did you ever see the outtake where Andi Peters kissed one on air - and burned his lips? They have improved a bit since then but they all do quite a good impression of a radiator.
  4. dUnKle
    dUnKle
    Jan 1, 2001
    13,712
    +1,499
    my 5200 gets bloody hot - very bloody hot
    so much so that last winter I just turned off the radiator in my room - and thats the truth
