Heat DTS
Discussion in 'Movie Forum' started by Spazwunkle, Aug 10, 2003.
  1. Spazwunkle
    Spazwunkle
    Went looking for the Ronin DTS release over at Movietyme, but what do I see? Heat DTS!!!!
    I haven't heard anything about this. So just wondering if anyone has got it? and what's it like.
    Is it an improvment over the old, not likely to be reissued, 5.1 flipper disc?
  2. monkeyWRENCH
    monkeyWRENCH
    Jan 6, 2002
    1,011
    +36
    I believe the DTS version is cropped to 1:1.85
  3. Mikkis
    Mikkis
    Yep, that Korean version is a 2-disc. Disc 1 has the correct aspect ratio of 2.35:1 with DD 5.1.
    Disc 2 has the cropped picture 1.85:1 with DTS. Why they used a cropped picture for the DTS version is beyond comprehension. :confused:
  4. Smurfin
    Smurfin
    Aug 13, 2002
    20,641
    +4,004
    Can anyone report if the soundtrack is particularly different?
  5. Mikkis
    Mikkis
  6. Smurfin
    Smurfin
    Aug 13, 2002
    20,641
    +4,004
    Thanks, sounds like I'm better off keeping my R1 copy. 1.85:1? no thanks...
  7. FoxyMulder
    FoxyMulder
    I have the region 1 version of Heat too.
    Good picture enhanced for 16/9 televisions and shown in its correct aspect ratio of 2.35, the sound is Dolby Digital and is very good and the film fits on one disc.
    I wouldnt buy a DTS version just because its there i'm a huge DTS fan but a compromised ratio NO WAY.
