Heads-up for other Z2 owners...
Discussion in 'Projectors, Screens & Video Processors' started by Jimbobgod, Jan 11, 2004.
  1. Jimbobgod
    Jimbobgod
    Feb 23, 2003
    St Albans
    I just popped the cover off the mains plug supplied with my brand new Z2 and was surprised to find a 13A fuse - which is a bit excessive for a unit rated at 1.3A! Anyone else noticed this?
    Jimbob
  2. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    my little panny 100 wanted a 13A fuse in its plug too (check manual)
    Anim
  3. Jimbobgod
    Jimbobgod
    Feb 23, 2003
    St Albans
    I've looked through the Z2 manual, and I can't find any reference to the unit requiring a 13A fuse. Why would it if it's only drawing one tenth of the current?? :confused:
  4. The Nightfly
    The Nightfly
    Aug 31, 2002
    814
    The New Frontier
    +24
    If it was being plugged in anywhere else in the world the plug wouldn't have a fuse anyway. There is probably an internal mains fuse of the correct rating.
    Allan
  5. Jimbobgod
    Jimbobgod
    Feb 23, 2003
    St Albans
    Ahh...yes, that could well be the case. But I bet the fuse in the plug-top is a lot less hassle to change than one inside the projector itself ;)
    Jimbob
