Headphones with LG RZ-42PX11
Discussion in 'Plasma TVs' started by simon33, Apr 2, 2005.
  1. simon33
    simon33
    I recently visited a local shop to view this plasma and was very impressed. I managed to have a quick peek around the back of the plasma and to my dismay I couldn't see any sockets to plug headphones into.
    Can anyone confirm that this is true, and if so, is there any way possible to use headphones with this plasma?
    Many thanks in advance, :)
    Si.
  2. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    I can confirm there isn't a headphone socket, but I don't know if there is a way around this.
  3. simon33
    simon33
    Thanks Ross-P.
    Out of interest, why doesn't a company like LG just put a headphone port in?
    I can't imagine it being very expensive to do at all... weird?!
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    There must be a line level audio out, why not connect that to a hi fi or AV amp?That will give you the headphone connection.
  5. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    I suppose being a budget model corners have to be cut like no headphone socket, only 1 RGB. The only way I can think of is if you're getting a home cinema surround system in the future you should have a headphone socket on that.
  6. simon33
    simon33
    Thank you both for your replies.
    Before I buy a home cinema system or a hifi, could anyone tell me if the LG has an audio out of any kind?
    Thanks!
    Si.
  7. AudioSlim
    AudioSlim
    Dec 28, 2004
    1,060
    +76
    What are you connecting to it?
    If it's Sky or Sky+ or DVD then that will connect directly to your (new) surroud amp or whatever directly for sound, and only connect your sky to plasma for video etc.
    Dont know if your plasma has audio out in any form but saying all that if the internal tuner in your plasma is the only thing you've got then you aint getting anywhere near what you should out of your plasma. For a kickoff if you using the analagou tuner then it wont be widescreen and so on.
    SLIM
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    scart should give you an audio out for internal tuner anyway so dont worry about a specific one too much (your DVD, Sky etc will go direct to amp) see this thread for more info on surround sound systems with plasma: http://www.avforums.com/forums/showthread.php?t=154292
  9. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    Simon33 there is an audio out around the back of the TV.
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Ascertained by observation, Ross? Useful to know that as it's not listed on LG website. I've never had cause to look for it on the TV.
  11. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    Yes by observation MAW, you are right the LG website dosen't list it or half of the TV's other features !. I got more info on the TV off of other websites when I was first looking at it.
  12. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Like HDCP for instance. They don't do themselves any favours do they?
  13. nipbiplip
    nipbiplip
    Feb 5, 2005
    3,315
    On my Manor
    +570
    SCART 2 on the back of the tv carries an audio signal. Connect this to an amp or another audio 'in' device. This will produce audio out regardless of which input you're waching.
    Hope this helps.
  14. Ross-P
    Ross-P
    Mar 16, 2005
    391
    Guernsey
    +20
    I agree MAW the LG website is vague to say the least !
