Headphones with big cups....ooer
Discussion in 'Headphones, Earphones & Portable Music' started by nightofjoy, Mar 1, 2013.
  1. nightofjoy
    nightofjoy
    Jul 11, 2012
    59
    +7
    Hi.
    I'm looking for a set of headphones with cans big enough to sit right over my ears with plenty of clearance (not that I have massive Dumbo ears). Not pads that sit against the ear, which give me problems.
    They can be as clunky as you like, as they'll be used indoors or under a hoodie when out, or for long train journeys. They don't specifically need to be for portable media, although I'll be using them mostly with my ipod. Lets say no more than £100?
    Can anyone who's a headphone whizz throw some makes & models out there?
    Cheers.
  2. Drubbing
    Drubbing
    May 5, 2009
    1,299
    +159
    Fit is entirely individual. You can find plenty of over ear cans at that price - whether any will sit right off your ears is down to who they fit YOU.
  3. nightofjoy
    nightofjoy
    Jul 11, 2012
    59
    +7
    Yeah, I know, I just thought somebody out there who might be a headphones expert could provide a list of models which have cans large enough to fit over the average ear completely. I'll be buying online so I won't be able to try them, and not all listings cover details like this......
  4. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,608
    Aberdeenshire
    +181
    The Audio Technica m50 are very highly rated over ear headphones and look like they have roomy earcups. They're over budget at around £130 but by all accounts are a bargain and should give a far superior sound to anything costing £100.
  5. nightofjoy
    nightofjoy
    Jul 11, 2012
    59
    +7
    Cool, there's one to look in to! :)
  6. Member 266567
    Member 266567
    Mar 18, 2008
    584
    Near Brighton
    +81
    The SoundMAGIC HP100 and H200 have particularly comfortable and large ear cups, but again are quite a bit over budget. The drivers are a massive 53mm and the pads are really big for a semi-portable pair.
  7. Tran67
    Tran67
    Aug 27, 2012
    65
    +7
    Brainwavz Hm5 from Amazon or Mp4Nation are large cans with decent sound
  8. Member 372856
    Member 372856
    May 7, 2009
    110
    Stockton-on-Tees
    +27
  9. Tran67
    Tran67
    Aug 27, 2012
    65
    +7
    Virtually the same headphones as the Hm5!!
  10. Member 372856
    Member 372856
    May 7, 2009
    110
    Stockton-on-Tees
    +27
    Same OEM. See also Fisher Audio FA-003.
