Headphones Querry with TV
Discussion in 'Plasma TVs Forum' started by roy c, Jan 31, 2014.
  1. roy c
    roy c
    Aug 3, 2007
    68
    I have a Panasonic TX-P42ST50B .
    1. Can I use headphones without it altering the normal TV sound output? -I notice the set has separate headphone volume controls so hoping this will be possible.
    2. Can the headphones be wireless? If so how do I set it up?
    Thanks in advance
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  3. JayCee
    JayCee
    Jan 20, 2004
    23,762
    Lanarkshire
    +2,570
    As you already have the Tv (and headphones I presume) why not try it?
    Yes, the headphone vol control works independently of the speakers.
    Yes, wireless headphones can be used and the sender unit would plug in to the headphone socket.
  4. roy c
    roy c
    Aug 3, 2007
    68
    Thanks, no I do not already have headphones and I did not want to buy any if it would not work. I was advised that it would be best to plug the sender unit into phono plug sockets (via an adapter) by a Pansonic dealer but I am darned if I can see any phono plug socket on the set!
