Well I got my arctis 7x yesterday (thanks @Dazimus) and I just swap the dongle between devices, so far the ps5 and xbox series x.
Also plugged the dongle into my macbook silicon m1 did a full reset of the headphones (as 2nd hand) and changed the settings on it, set the eq and whatnot.
Very happy with the sound![]()
I don’t think I could own any other gaming headset after trying the Audeze Mobius/Penrose. They’re leagues ahead of anything I’ve heard.
Still loving my ones.Arctic 7X back in stock at SS.
Arctis 7X Wireless Gaming Headset for Xbox
The SteelSeries Arctis 7X wireless gaming headset for Xbox is designed for Xbox Series X|S with backwards compatibility for Xbox One and has long-lasting 24 hour battery life.steelseries.com
REINESSA12 for £141.
And what EQ do you have the 7x set to in the steelseries app?Spent 20 mins comparing DTS Inbound (trial) vs Dolby Atmos (purchased).
Id initially just ‘set and forget’ the Atmos app, but after trying DTS:X and finding it seemed to do a lot more to the sound, had a poke in Atmos and found that turning off Performance mode gave a sound on par to DTS:X.
I then found Atmos had an EQ.
the internet says in a battle of DTS:X vs Atmos, it’s personal preference. My point here is, if you haven’t touched either app, get the trials installed and have a play.
they immediately improved my 7X.
If you turn off performance mode you get worse directional sound.Spent 20 mins comparing DTS Inbound (trial) vs Dolby Atmos (purchased).
Music with custom tweaks...And what EQ do you have the 7x set to in the steelseries app?
I have mine on "immersive".
I'd say Atmos sounds better as in - just listening to stuff its a nicer sound. DTS:X has better directional information.....
ThanksFound a pic of the EQ I have...
No idea really. I literally spent 30s in the app, applying my go to ‘v’ (high lows/high highs). I never compared one with another, nor did I even try the phones on flat.Thanks
From memory its fairly similar to the immersive setting?
Im contemplating going back to ‘flat’ and using the EQ in Atmos however.
Aye. Double EQ’ing would just end in a world of hurtI do believe that if you want Atmos to work correctly you have to have the 7x Series App EQ set too Flat.......read up on it somewhere.
I had XO7's and they technically are still great, but I got a Series X on day one, and so I also got the new Stealth 700 gen 2 headphones, which sound awesome as well, and are completely wireless. My only issue with them, is if you turn off your headset while the xbox is on, you will disconnect the Bluetooth from not only the headset, which is normal, but also the series x controller, which is definitely NOT supposed to happen. If you power down the xbox from the UI, it will shut down all 3 just fine. One more issue, is once the controllers Bluetooth is disconnected via the headset, the only way to reconnect is to shut down the xbox entirely, then unplug it...wait a few seconds and plug it back in.....very tedious process.My Turtle Beach X07 are on there last legs.
What headphones does anyone recommend for the series x. Around £70 or under.
Xbox Wireless Headset | Xbox
Game loud and clear with the Xbox Wireless Headset, featuring auto-mute and voice isolation for crystal-clear chat, intuitive design, and direct pairing to your console.www.xbox.com
$100 so looking like thier own version of the Pulse headset in the same price range. Look decent.
