steelydanfan
Do you have a link?
Exactly my thinking. Hard to find any major difference between the 1 Wireless and 7X other than a big difference in price. Mine should arrive Tuesday...Just ordered a set of Steelseries Arctis 1 from their own website and if you log in as a member there's 25% off various stuff.
I couldn't see that the 7X justified the extra cash, and £75 seems like a decent price for a set I can also use on PS, PC and Switch.
What a steaming pile of donkey dung. Should be called Turtle's Head. I downloaded the app for Android - Audio Hub - it then says a critical firmware update is available get the app! I'm using the chuffing thing.Bought the TB Stealth 700 Gen 2![]()
I've got the Stealth 600 (Gen 1), so can't use the mobile app and have to use the desktop app. However, it wouldn't recognise the headphones were connected to the laptop with the supplied USB cable, so I used another cable I had and then it detected it.What a steaming pile of donkey dung. Should be called Turtle's Head. I downloaded the app for Android - Audio Hub - it then says a critical firmware update is available get the app! I'm using the chuffing thing.
I'm not alone in my woes looking at the reviews.
I've also got the Stealth 600's and dug them out yesterday to charge them up in case I hurled the others across the room.I've got the Stealth 600 (Gen 1), so can't use the mobile app and have to use the desktop app. However, it wouldn't recognise the headphones were connected to the laptop with the supplied USB cable, so I used another cable I had and then it detected it.
I ordered the 7x on Wednesday, and had the shipping email on Friday saying that they'll be delivered on Wednesday this week (they are currently in Germany according to UPS).Anyone had any issues ordering from SteelSeries direct? I ordered the Arctis 1 Wireless for Xbox on Thursday, and the status is still saying 'Preparing for Shipment'.
Thought it would have shown signs of movement by now, delivery estimate is tomorrow or Wednesday. Maybe I'm just being a tad impatient?
SteelSeries aren't exactly clear about them that's for sure. Looking at the Arctis 1 - there are a number of varieties - standard Arctis 1 (wired), Arctis 1 Wireless, and Arctis 1 Wireless for Xbox. There are probably others too.I ordered the 7x on Wednesday, and had the shipping email on Friday saying that they'll be delivered on Wednesday this week (they are currently in Germany according to UPS).
Having seen your earlier post about differences between the 7x and 1 wireless for xbox - I'm now wondering why I didn't go for the 1s too! The only difference I can see is in the headbands, the chatmix dial (which I probably won't ever use) and the mic is removeable on the 1s and retractable in the 7x's. I think I probably looked at the non-Xbox 1s and ruled them out as they needed to be wired to the controller![]()
