spikecast
Mic monitoring has always been an issue with Astro headsets, you have to shout into them for it to work.
I'm sure my wife would love that at 2am " yes luv I know I'm shouting but I have to so I know how loud I'm talking" lolMic monitoring has always been an issue with Astro headsets, you have to shout into them for it to work.
Hyper x clouds. Not cloud II's you won't be disappointedHi guys and gals!!
I'm looking to invest in a pair of headphones. What can anyone suggest?
I'm not fussed about it being wired or wireless but would like it to over the ear, not too loud to other people in the room. good for voice chat too. Also will need it to work with both the XO and PS4.
Thanks in advance
Right just pulled the trigger on gen 3 a50s from amazon to replace my gen 2, not fussed about mic monitoring so what's the deal update and set as pro? How easy is it to do? Thanks and I'm hoping battery life is as good as they say as that's a big plus for me [emoji106][emoji106]
Quick question about A50's.
Just made the switch back to Xbox from PS4. Does the headset still need to be attached to the controller for the mic to work? If so I'm guessing I need a 2.5mm to 3.5mm lead rather than a chat adaptor as the One S controller has a 3.5mm jack.
TIA
For the new a50s you don't need a chat cable they are completely wireless on the Xbox one version
Mine are Gen 1's
Thats what I thought. Off to ebay then.Then yes you will need a chat cable mate [emoji106]
Last quick question, is it only the Gen 3's that are completely wireless or Gen 2's also?
Just had a quick go on gen 3's updated and set in pro mode, it sounds completely different to my gen 2 which setting on actual headset are people using 1,2,or 3? Left them on charge now [emoji106]
Different in a good or bad way?
You got a link to them please mate.An update on my gen3's wasn't happy with the presets even the pro one as I mainly play fps games, and found them too bass heavy so a bit of research on the AstroGaming forums and have found that someone has uploaded a zip file with three eq files for shooters it now sounds great really happy with them now [emoji106][emoji106]
