Headphones (again) (sorry)
Discussion in 'Headphones, Earphones & Portable Music' started by meddyliol, Jul 24, 2005.
  1. meddyliol
    meddyliol
    May 11, 2005
    45
    What exactly are 'canal' style headphones? I would like Senheissers, do they do 'canal' and 'earplug' type. Is it possible to get used to earplug type 'phones? What is wrong with the old fashioned 'cans?
    Brian
    PS Sorry for yet another headphone question :devil:
  2. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    There is a whole forum dedicated to headphones here where I am sure you will get a more valuable answer to your question .....
    http://www.avforums.com/forums/forumdisplay.php?f=128
  3. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
  4. watchinthewheel
    watchinthewheel
    although you probably wont, they aint to quick there.
    canal ones fit into the ear canal not just the ear. i have tried them (sony ex-71) and found em really really uncomfortable, though some peoiple swear by them. they kill pretty much all outside noise which is cool as long as you arent doing anything at the time.
    i recently got some sennheiser mx500's and they aint bad, although i dont think they are much better than the stock sony ones tbh, then again i like the sound of the stock ones anyway. if your looking for new 'phones they are still probably your best bet though.
