headphone problem
Discussion in 'Headphones, Earphones & Portable Music' started by statler, Oct 27, 2005.
  1. statler
    statler
    Iam a newbie and i realise i may be doing something incredibly stupid here so dont laugh.
    Whenever i plug my headphones un hd600's into an arcam 8 amplifier.
    Sound still comes out the speakers.
    WHY?
  2. shahedz
    shahedz
    Apr 26, 2005
    11,118
    +2,045
    this is quite common with most seperate amps. dont know why, but do you have a speaker swith, (usally turns on speaker set a or b on or both on , or both off) as you have to turn the speakers off, not sure if your Arcam has the speaker switches
  3. fathervic
    fathervic
    Jul 6, 2005
    285
    Scotland
    +18
    There is a speaker switch for the Alpha 8 but only for speaker set 2. From my recollection (it's been some time since I had mine) the speakers should cut off automatically when you plug in your 'phones. The easiest way to remedy this for now is (if you single wire your speakers that is) connect your speakers to set 2 and switch them off when you want to do some private listening.
