headphone jack adapter help needed please.prob something simple please look in.
Discussion in 'Headphones, Earphones & Portable Music' started by SILVERBACK, Dec 25, 2004.
  1. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    basically i got my dad a pair of headphones for watching tv at night and i got an extension cable but when i hooked up the extension cable to the headphone cable the end terminal is to big for the tv socket:( whats the name of the adapter i need ? hope that makes sence lol.
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    I assume you need a 3.5mm male -> 6.3mm female tele adapter, but make sure it's stereo (three sections on the plug).
    You may also want to get a short 3.5mm -> 3.5mm stereo tele extension cable, so that you can plug the adapter and headphone plug into the extension cable instead of directly into the TV. If you plug the adapter and headphone plug directly into the TV, they may weigh down on the socket and increase the risk of it or the adapter getting worn out or breaking.
