headphone extension lead
huwg
I'm looking for a headphone extension lead (non coiled) 3-5M to be used with Grado SR60's
I know Grado do their own (£27 :eek: ), but can anyone recommend any cheaper alternatives?
huwg
Thanks,
I suppose it's just a case of getting a half decent one, rather than the ultra thin £1.99 jobbie that is often available.
huwg
Ah,
that looks more like it.
After spending lots on decent interconnects etc it seemed a shame to use a bit of wet string to plug a nice set of headphones in without going OTT on Grado's own make. :smashin:
S
splatterhouse
reevesy said:
i got one of these as i did'nt fancy spending too much or getting one of the thousands of couple of quid jobbies....very well made good quality cable and does the job.
http://cgi.ebay.co.uk/Neutrik-Van-D...oryZ3274QQssPageNameZWDVWQQrdZ1QQcmdZViewItem :smashin:
Wow, glad I saw this post - I was looking for the exact same thing for my HD25BA's.
One thing I just cannot find anywhere is a decent 6.3mm jack-3.5mm socket adaptor, as the HD25BAs unfortunately come with a 3.5mm jack. Does anyone know where I can find a decent adaptor? I can only find cheap ones like this on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=5819930181&ssPageName=STRK:MEWA:IT
Or should I just get one of those, will it make much difference to sound quality?
huwg
I ended up buying the Neutrik/van damme cable from Robert Schofield,
very solid and chunky, a bargain when you look as the price of the neutrik connectors.
