Mr Edwards
Any reccomendations on headphone extension leads for Sure SRH1540, the ones in Richer Sounds seem a bit expensive at £50.00 for 3m length.
You can find them for a couple of quid cheaper, but they are the ones I use as the connectors are so good they will take a real hammering.Any reccomendations on headphone extension leads for Sure SRH1540, the ones in Richer Sounds seem a bit expensive at £50.00 for 3m length.
