Headphone dac and amp for Bose AE2i
Discussion in 'Headphones, Earphones & Portable Music' started by rosenelson, Aug 22, 2013.
  1. rosenelson
    rosenelson
    May 4, 2012
    389
    +18
    All, I recently bought AE2i and use it on the move with iPhone playing FLAC files. I am happy with the sound at the mo. but was wondering if anyone has used a Portable DAC with this headphone and what do they recommend. Yes I admit that on here I once said I'll never go chasing better sound quality, but I was wrong and here I am looking to see if it could be better.
  2. TheNameIsJambo
    TheNameIsJambo
    Feb 4, 2011
    6,141
    Fife
    +1,696
    You'd probably benefit more from using a Line Out Dock cable, into a headphone amp.
    You will notice a fair increase in fidelity when you use one of those.
  3. Member 266567
    Member 266567
    Mar 18, 2008
    584
    Near Brighton
    +81
    That's a good point! You have to spend quite a lot for an Apple compatible portable DAC/Amp. You will notice improved sound from a line out doc cable and a decent amp. FiiO have a range of affordable and great quality amps - well worth a look at.
